Harley-Davidson Street 500 and 750
Speedometer question
Old May 4, 2017 | 09:52 AM
Patrick G. Dulaney's Avatar
Patrick G. Dulaney
6th Gear
Originally Posted by lh4x4
The rpm and trip B showed up for the 17's but no gear indicator.
My 2017 Street Rod has digital RPM and gear indicator together
Old May 5, 2017 | 12:24 PM
ktp1598's Avatar
ktp1598
Just talked to my local parts department and they had a 2017 cluster in stock but he thinks it may not hook up. I'll have to do a bit more research on this or take my cluster in to compare them. More to come....
Old May 5, 2017 | 08:07 PM
ktp1598's Avatar
ktp1598
Seems as though the 2017 speedo really is different than the 2015-2016. The older ones have a double 6 pin plug and the 2017 has a single 12 pin plug. The ECM also has a different part #. If Harley releases a combo speedometer/tachometer it'll have to have a harness adapter with it. Without knowing that the ECU will send the info the cluster needs I think I'll just use an aftermarket tachometer. Probably digital as those don't bounce or jump. Also want to look for one that has a gear indicator. I'll report back as soon as I find one..
prondas
Feb 23, 2017 07:27 PM
blarg
Dec 19, 2011 08:02 PM
Texas_Campers
Feb 6, 2011 06:13 PM
texas-buzzard
Aug 4, 2009 03:02 PM
spiritwarrior
Jun 28, 2009 07:53 AM
