Harley-Davidson Street 500 and 750
no spark
Old Feb 10, 2023 | 02:14 PM
smitty901's Avatar
smitty901
Originally Posted by nevil
Don't know if it applies to the Street bikes, but in general if the ECM does not detect compression in the cylinder (as with the spark plug out) it won't send power to the plug wires. You need to use an inline spark tester.
It will spark with the plug out. Bike has no way to tell if it has compression or not.
He needs a code reader. With out one is makes things a lot hard to track down or to eliminate as a cause.
2015 Street will not display DTC in the speedometer .
After check the kill switch AKA Engine shut off switch.
The ignition switch needs to be check.
Old Feb 10, 2023 | 10:01 PM
Rodney Graham's Avatar
Rodney Graham
unpluged the switch still no spark
Old Feb 11, 2023 | 09:55 AM
smitty901's Avatar
smitty901
Good chance the ignition switch or one of the relays is bad.
I will send you some things to look at.
jim70
Oct 4, 2016 07:16 AM
idrivemywifecrazy
11
Sep 19, 2013 04:40 PM
vonh
Apr 24, 2013 02:11 PM
dustinbit
Feb 20, 2012 07:01 PM
dguse
Feb 1, 2009 02:47 PM
