Sportster 883 down, throttle stuck open, now wont push start
Old Sep 24, 2014 | 09:06 PM
waraas's Avatar
waraas
Stage I
Exclamation Sportster 883 down, throttle stuck open, now wont push start
hey guys, so my 07' 883 sposter just died in the weirdest way. I stopped for gas and filled the tank up, I then tried to start the bike the normal way and it would not start, the starter felt like it was going smooth (it was clicking loudly) and it seemed to have enough power, but it wouldmt start.
I then called 2 of my buddies and they helped me push start the bike. BUT when I got it going via a push start in second gear, the engine rev'ed up big time like the throttle was stuck. Because it was rev'ed up so high I turned it off to examine. I didnt see anything wrong. Im pretty sure the throttle was not stuck
We then push started it again, and it did the exact same thing, but this time I tried to head home with the engine rev'ed up really high. I kept the bike in 3rd gear and kept the brake on so I wouldnt go fast.
I made it a few blocks but then the engine started sputtering and then it died. When it died I was going about 30 mph, so I slowed down and tried another push start at around 10 mph, but when I did that the back tire froze and nothing happened.
So now its in a parking lot not working
Im thinkin the problem has something to do with the computer. Now the bike wont even turn over (no click from the starter) and when the keys are in the bike and i pull on the break, the lights go dim and the milage indicator goes blank, which i thought was really weird.
Im hoping someone has some info about this, I have no clue whats going on? thanks in advance
Old Sep 26, 2014 | 10:07 AM
JustDave13's Avatar
JustDave13
The rear wheel locked?
Remove the spark plugs to check if the engine will turn over. Put the bike in 5th gear and push it with the clutch engaged (lever out)
If the pistons move up and down that's a good thing, if the rear wheel is still locked up then you have some problems.
Welcome to the forums
chevdude
Oct 9, 2017 10:10 AM
tvon
Apr 27, 2015 12:26 AM
Gooberguy
Jul 20, 2011 09:37 AM
softail04
Ironhead
Feb 27, 2009 05:24 PM
dhc8guru
Dec 21, 2007 09:35 PM
