Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I was told I should get an ignition that will set the advance to zero for starting. Not sure if my Daytona Twin Tec will do this. Gotta find the documentation.
DTT is all you need.
If you can get the cable (program can be down loaded from site) it has a bunch of options to use while tuning.
Even without the cable go check out the site so you know how to use those dip switch's.
The DTT will unlock a bunch of power out of a 98"
I ran the Daytona Twin Tec on my 98 inch carbed bike with woods cams and high Comp. just find a mechanic that understands that ignition module. its all you need.
