Base calibration help needed
Old Feb 14, 2015 | 10:33 AM
lt4buckeyes's Avatar
lt4buckeyes
Default Base calibration help needed
Hopefully this doesn't sound too stupid, but I just installed an SE intake...the one that uses the OEM intake cover. I have a 2014 Ultra....basic, nothing but Rinehart slipons. What base calibration should I start with. The closest was "617SEN204", but that has a SE exhaust, which I do not have...will this make a difference? The next question is...what calibration should I use after I install the Slimline Duals from Rinehart
My plan is to get the bike Dyno'd, but I wanted to play with the tuning a bit myself...and maybe learn something. I also wanted to know how to set the calibration back to factory.
Thanks
Old Feb 17, 2015 | 08:34 AM
tv7son's Avatar
tv7son
the 610SEN204 is for the Twin cooled motor.
You need the 617SEB204 for your air cooled Ultra.
That same file is good if and when you change to the new muffs.
Old Mar 15, 2015 | 12:20 PM
Yankee11011's Avatar
Yankee11011
Stage IV
I need help if anyone knows the MAP for 2013 Ultra Classic Limited with Stage one breather and Rush Big Louie Slip-on 3" Baffle. I can not find one the closest of have seen is 617SEN204. I found this but it says 2010 to 2013 1580 is this right I thought the 103 was 1690, Anyone have any ideas, thanks
Old Mar 15, 2015 | 08:31 PM
Sparkee...'s Avatar
Sparkee...
The 044aao003 map was recommend for my 2013 Electra Glide Classic. You will need to re-enable the automatic compression release.
goshivan
General Topics/Tech Tips
Jun 15, 2017 01:51 PM
Andy Knell
Aug 14, 2015 08:00 AM
Airborne350G
May 4, 2012 06:37 PM
440racer
May 5, 2010 07:06 AM
jimclaypool
Aug 31, 2007 10:17 PM
