SEPST map
Old Apr 30, 2012 | 12:23 PM
Airborne350G's Avatar
Airborne350G
Default SEPST map
OK Have a question. I found two different maps that fit my application which one should I use for the following:
2012 Ultra Limited 103 (1690 cc)
SE A/C
Rush True Duals
Rinehart 4" mufflers
SEPST
Also does anyone know of a good tuner in the Northern VA area that knows the SEPST? Also is there a way to save the current map in case I do not like this set up and want to go back to stock?
Old Apr 30, 2012 | 04:53 PM
Airborne350G
Anyone????
Old Apr 30, 2012 | 05:01 PM
1st 96 ultra's Avatar
1st 96 ultra
well don't know if it will help but been checking into maps for the wifes Heritage I just put duals on and from what I have found out on here is you can save what ever is in there , although sort of gave up my search and going to have dealer do a dowm load for warrenty reasons and I am not trying to run a 1/4 mile or anything , just looks and sound and want it to run right , may be more will chime in , you might check the tec area
Old May 4, 2012 | 03:08 PM
Airborne350G
Bueller, Bueller??
Old May 4, 2012 | 04:20 PM
glmf's Avatar
glmf
try to post in this thread and you will get a ton of info,,https://www.hdforums.com/forum/elect...on-thread.html
Old May 4, 2012 | 06:37 PM
Airborne350G
Thanks, Posted there also and got crickets.
But figured out that my bike wants the 044 file.
weezer_nd
2014-2024 Touring Models
Jun 10, 2016 06:17 AM
mmesa005
Dec 8, 2011 03:31 PM
Delta
Mar 11, 2011 03:31 PM
magnoliarunner
Oct 28, 2008 09:54 AM
DeathWind
Jun 15, 2006 06:31 PM
