ignition issue ?
Old May 7, 2015 | 10:52 PM
colwell's Avatar
colwell
6th Gear
Default ignition issue ?
2001 Electra Glide Classic carb model.....tachometer quit working and it started backfiring and missing....no upgrades....Pulled plugs to check spark and plugs started lightly firing with only ignition on....was 5 feet away from the bike...any ideas or anyone had this issue?
Old May 7, 2015 | 11:18 PM
Ed Ramberger's Avatar
Ed Ramberger
Check charging system voltage - if it's charging up over 15V the tach can become inoperative and it can run weird. That's a 30 second check that should be done occasionally.
I don't understand your firing description or the part about being 5 feet away from the bike. Another couple of things could be the crank position sensor or ignition module.
Old May 8, 2015 | 12:16 AM
colwell's Avatar
colwell
6th Gear
The spark plugs were firing without me turning over the engine....I stepped away to grab some new plugs and heard them clicking .....
Old May 8, 2015 | 04:36 PM
colwell's Avatar
colwell
6th Gear
Well I changed out the crank sensor and then tested its good got 4 on ac meter ......think it's volts....onto more wiring and a donor ICM if I can find one just to see if its the issue.
Old May 10, 2015 | 10:32 AM
colwell's Avatar
colwell
6th Gear
Found the running issue was a plugged up speed sensor....still no tachometer and it has an engine codes 25...don't know if it came on from me testing or there is still an issue
Soarer77
Ironhead
23
Oct 3, 2024 03:45 PM
crestwood
Electrical/Lighting/Alarm
14
May 27, 2024 02:48 PM
Bcoish
EVO
11
Apr 29, 2019 09:09 PM
Swamphunter
Sep 4, 2008 08:51 PM
zenwarrior
Sep 13, 2006 01:17 PM
