2013 cvo road glide sepst tuner and map
Old Jun 6, 2015 | 07:39 PM
Rickpay1's Avatar
Rickpay1
Default 2013 cvo road glide sepst tuner and map
2013 cvo road glide with the Harley sepst. I downloaded the canned stage one map from Harley. Bike is stock with 2.25 fullsac baffles and decatted headpipe. The problem I have is got a lot of decel popping and bike still seems to be running lean. Is there a better canned map to use from Harley or am I going to have to go get it a dyno run and tune to fix it...any help would be appreciated. Also and good tuning guys around Richmond va? Going on a run in a month to Harley museum and want to get it right.
Old Jun 6, 2015 | 11:41 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
You may have an exhaust leak around the flanges from changing out the header, or not. Check the torque on all 4 nuts. I'd take the bike in for a Dyno tune at the first available opportunity as a canned download will only get you so close to where the bike really needs to be because the airflow through the engine has been changed with the addition of the de-catted headerpipe.
Keithhu
Milwaukee Eight (M8)
87
Aug 2, 2022 07:30 PM
BlackBastard
Apr 13, 2016 06:44 PM
MajorGeek
Dec 3, 2015 11:00 PM
fatbobbranden
Jan 28, 2009 10:18 AM
dashiell
Apr 16, 2006 01:17 PM
