Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have started with map dni176.
set all afr to 14.6.
set pe to 10000 rpm.
disabled knock control.
ran several datamaster runs collecting as much data as i could then vtune after each one.
can someone look at my current ve tables i have generated and guide me as to how to blend?
Also i see you can add more then 1 file to vtune at a time? i have been running 1 , then running it through vtune then generating new map never adding more then 1 at a time. is this correct?
Thanks in advance.
