Starter Replacement
Old Jul 18, 2015 | 05:58 PM
BLKPRLFLHTCU's Avatar
BLKPRLFLHTCU
I would be surprised if the starter was done unless there is some compression upgrades to your bike. Make sure you battery cables are clean and tight, put a battery tender on it for the night before you pull things apart even a boost may show you the starter is ok. Even a year old battery can go bad under certain condition, especially if its a poor quality unit.
Old Jul 20, 2015 | 08:29 AM
triplj's Avatar
triplj
Thanks for the replies everybody. I cleaned up the battery terminals and connections over the weekend. It is a little better, but I will probably end up taking to an indy shop that I use and have him take a look at it. It starts right up occasionally now, but still does the stutter start 2 times out of 3. Sounds like a ghost in the machine!
ksimo32
Electrical/Lighting/Alarm
Apr 5, 2021 07:51 AM
WildBill_50
Mar 14, 2013 07:16 PM
deadeye
May 8, 2012 08:04 AM
Bama91
EVO
55
Mar 11, 2011 06:36 AM
73shovelheadude
Oct 6, 2009 08:41 AM
