Bus er
Old Sep 26, 2015 | 07:45 PM
NicNic's Avatar
NicNic
Stage I
Default Bus er
A bus er code came up on my 2008 ultra classic...checked all connections and bus er code is out .....fuel pump now won't prime but bike will turn over and won't start...
Old Sep 27, 2015 | 08:08 AM
llewop's Avatar
llewop
Default Bus er
I also am / was experiencing bus ER display and multiple codes on my 2007 ultra classic. Took it all apart cold find no loose, chafed, shorted, damaged wiring. Took it to the dealer. Ran scan tech diagnostics. Found no problems even when codes display and all alarm lights( check engine, battery, security) are on.
Also, you won't believe this, when I use CB radio and transmit, the engine begins to sputter and miss fire. When i release th PTT button, everything returns to normal.
The bike continues to run great even with alarms and bus ER. I'll figure it out and post results.
lospecht
Mar 6, 2016 05:46 PM
raylikesbeer
Jan 30, 2008 09:22 AM
Crunchking
Apr 8, 2007 11:25 PM
SGLarry
Mar 28, 2007 02:22 PM
SGLarry
Mar 28, 2007 02:20 PM
