No electrical power
Old Oct 9, 2015 | 06:29 PM
rodney3744's Avatar
rodney3744
Stage I
Default No electrical power
I have a 09 fatboy, other then some chrome everything is stock.I turn the switch on. Activated the on/off switch, electrical power came up, waited for the appropriate time, hit the starter switch got half a turn on the starter then everything went dead. I have no electrical power for lights or anything, switched to auxiliary and the millage displayed but nothing else. I checked all the 15 amp fuses and they are fine. Were should I go next please?
Old Oct 9, 2015 | 08:14 PM
chief08's Avatar
chief08
unplug ignition switch see if it's getting power. if so use jumper wire if u get lights start up it's switch. check all your cables for good connections. ground wires do this first then check switch.
Old Oct 9, 2015 | 09:33 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Check all the battery cables on both ends for corrosion and tightness. Always start with the cheapest remedies first!
Kevlar
Electrical/Lighting/Alarm
Aug 19, 2016 12:00 PM
SnoRider
Jul 14, 2016 03:45 PM
ROMPUS
Jun 27, 2011 08:20 PM
07DYNAGLIDE
Oct 7, 2010 09:30 PM
sobrbiker883
Jan 21, 2007 09:38 PM
