intermittent engine light
Old Jan 12, 2016 | 09:26 PM
robertjr102's Avatar
robertjr102
Default intermittent engine light
my engine light is coming on and off, 14 FLHTK, the bike is running the same as always. ECM P0051, P0154, P1353 and a BCM 62201. 2 of the codes I have from my 09, ECM 0154 (rear OX sensor inactive,) and P1353 (no F cyl. combustion). The other 2 are for the newer bikes? Also do the 2 codes I have from the 09 mean the same for my 2014? The bike is running good so F Cyl no compression does not make sense to me. Any help sure would be appreciated? Thanks
Old Jan 13, 2016 | 01:46 AM
Oz Nightrain's Avatar
Oz Nightrain
I had no combustion front and rear, while I was riding (go figure). It can sometimes be a 'false code' if that makes sense. Could possibly be thrown because of after market plugs, a loose cap on top a plug, a dodgy spark plug wire or something else in the ion sensing circuit. So I would check that stuff first, cheap and easy. Not sure about your other codes though, hopefully one of the more knowledgeable members will chime in. Good luck.
Old Jan 14, 2016 | 10:00 PM
Vernal's Avatar
Vernal
Try to clear them. Then check to see if they come back.
Try this site
http://www.fuelmotousa.com/p-29661-h...ble-codes.html
Old Jan 15, 2016 | 08:51 AM
robertjr102
Thanks
robertjr102
Jan 12, 2016 03:48 PM
HarleyGuy426
Jul 2, 2013 04:33 PM
tripacer1
Aug 31, 2012 08:32 AM
sickwithit
Jan 7, 2010 05:53 PM
joearizona
Jul 10, 2009 12:40 PM
