power vision, closed loop
Old Mar 16, 2016 | 10:05 AM
Fishonsc's Avatar
Fishonsc
Originally Posted by hrdtail78
The calibration that you used the first time it was working. Log your O2 voltage and see what they are doing. Are they hanging at a steady voltage, or they actively going up and down in voltage?
What should they do? Mine jump all over the place. Anywhere from .02 to .88 volts. Should they be jumping around?
Old Mar 16, 2016 | 11:07 AM
whittlebeast's Avatar
whittlebeast
They should constantly jumping up and down.
Old Mar 16, 2016 | 12:27 PM
hrdtail78's Avatar
hrdtail78
If you are in a steady state cruise in the area of the calibration that is set to be running with closed loop feed back. Your voltage should be switching back and forth from lean to rich. So, the voltage jumping up and down is normal and expected. If it isn't. Several things can be causing this. This is the first place I start when I am not getting closed loop feed back.
Old Apr 2, 2016 | 05:02 PM
gonzosc1's Avatar
gonzosc1
ok it is fixed, took me awhile but I went into reading mode to try and understand as much of this info as possible.
it was the O2 sensors. using the power vision gauge set up that I knew nothing about I was able to see what the sensors were doing. both sensors were dead. showing only 1.3 volts front and .2 volts rear when there were stone cold.
after bike warm up they were at .9 volts front and .2 volts rear. running the bike at various rpms only produced a reading of 1.25 volts front and .2 rear.
new sensors at 5 volts cold and after warm up right around 1 volt at idle. various reading as I go through the rpm range. bike is super smooth now and idle is steady. my shifter and linkage does not bounce like a sewing machine anymore haha...
and best of all I can auto tune now. thanks for the help gentlemen sorry for the delay..
brycenator
Jan 5, 2018 10:53 PM
fuelmoto
Fuel Moto / Jackpot Mufflers
24
Nov 20, 2016 11:44 AM
lionsm13
Apr 5, 2016 03:04 PM
oleboy
19
Apr 4, 2016 08:09 PM
aztsm
Feb 5, 2011 01:02 PM
