Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have a guy who's gonna tune my bike. (W/SERT). So, where's the best place to locate an 02 sensor on my SG? (He works on VRODs)
He feels the best way to tune the bike is placing a sensor properly(drill pipe, insert bung w/ sensorcollect data, and then correct SERT; rather than sticking a sensor in the pipes, and using full thottle data, etc.)
So I will purchase a set of primaries, place a sensor in it, collect data on a run, and correct SERT....
Just buy the headpipes for a 07 bagger - and use the bungs in them. When you are done, install the O2 plugs HD uses for international models. Or, at that point, you can run 3 wires to the ecm connector and make the bike closed loop by loading a closed loop map off the SERT and running O2 sensors.
