Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
My CLI % is between 95 and 103. Is that good or bad?
What is it at in the areas that you see timing being pulled? 95 or 103? 100 would be dead on. If it is at 95 the ECM is adjusting the the VE table to remove fuel in order to try and maintain the target AFR in your AFR table. So you would be a hit rich in those areas without the ECM adjustment. If it is at 103 the ECM is adjusting the VE table to add fuel in order to try and maintain the target AFR in your AFR table. So you would be a hit lean in those areas without the ECM adjustment. Look at the columns to the right in your spreadsheet. You can see the old VE value and then the new VE value.
I would pull a couple of degrees of timing from the spark tables (a little at a time) and once the pinging stops I would run a couple of auto tune sessions to clean up the VE tables for your spark table changes.
I'm not really sure what to tell you. Normally I would just remove timing in the areas that are showing knock but your log looks odd. Look at the timing for the front and rear cylinders (far right columns). In both of my bikes I have more advance (small bit 2 - 3 degrees) in the front cylinder than I do in the rear. I guess because the front is supposed to run cooler than the rear. In your log its the exact opposite. You are only getting knock in the front cylinder and none in the rear although the timing is almost always 7-10 degrees more in the rear cylinder than what is in the front cylinder when the knock is detected. Maybe it is that you are too lean in those areas. In the areas where it is pulling 7 and 8 degrees of timing you are in the open loop, so the CLI is of no use to determine how close your VE tables are mapped.
It is the spark tables from the dynojet tune for my bike. I will add some fuel and run another log and see what changes. Thanks.
I have been following this thread with interest because I have a 2012 FLHRC that has started to ping/knock quite a bit in many ranges. I have a PV as well so hopefully I can resolve this, but my question is - how do you know where it is knocking by looking at the log?
Sorry - do not mean to hijack the thread - hopefully just adding to it.
Regards,
When you make your log be sure to record spark knock front, spark knock rear, RPM and MAP. Most likely your max spark retard is set to 8 in your tune. Now go make a log. When you look at your log you will see a column for spark knock front and spark knock rear. Look down the columns. You will see numbers from 0 to 8. 0 is good. That means it is not pulling any timing. You will see numbers jump up to 8. Where you see that at is where she is pinging. For example. You might see in a row 2 2 2 4 5 8 8 8 5 4 2 2 2. Each number means how much timing it is pulling to stop the pinging. Now you can look at your log and see what RPM and MAP kpa it is pinging at and you can pull timing and or add fuel in that area of your tune. Start slow. Like only pull 2 at a time on your spark tables. I added alittle fuel and pulled alittle spark. Took care of all my pinging.
Regards,
Import your log into Excel and scroll down through it and you should be able to see where it is occurring. When you see a figure other than 0 in the "Spark Knock F or R degree" columns, the ECM is pulling timing because it determined knock in that area.
