Buttonless security system battery removal
Old Mar 31, 2017 | 02:12 AM
thefinn2's Avatar
thefinn2
Question Buttonless security system battery removal
How do I remove the battery without causing the buttonless security system to go off on a 2009 FXCWC? I put the key in the ignition to the ACC position as some guide I found online said, but the alarm still went off.
Old Mar 31, 2017 | 02:19 AM
skid_pimp's Avatar
skid_pimp
Not 100% on a 2009, but on my 2011 you have to pull the rear fender, or slide it out of the way at least. then disconnect the connector on the bottom right of the electrical caddy. Then disconnect the battery. All this has to be done while on the side stand, or it'll set the alarm off.
Old Mar 31, 2017 | 02:20 AM
skid_pimp's Avatar
skid_pimp
I think there is another procedure in my book at home as well, I can check later.
Old Mar 31, 2017 | 04:38 AM
warriordan89's Avatar
warriordan89
Stage III
Fob within range - turn key to on position - disconnect negative battery terminal first then positive.
Old Apr 29, 2017 | 05:44 AM
thefinn2's Avatar
thefinn2
That worked. I think my issue the first failed attempt was that I had the key in the ACC position. When I turned it on ignition, no squealing.
Battery is now on a tender getting ready for the season
Thanks!
Alter Kaker
Mar 17, 2019 10:53 AM
V-Twin
Nov 26, 2016 05:32 PM
craving94509
Jul 4, 2013 08:46 AM
Dynamite17
Mar 6, 2012 04:13 PM
rolodog
May 23, 2010 05:16 PM
