Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have a 2013 883 iron and the ecm is burnt inside so I want to fit a carb and ignition but I need an ignition that works on the crank sensor any suggestions
you might try giving thunderheart a call to see if their twin cam stand alone system can be used on your sportster, it is triggered by the crank sensor.
You may also need a different manifold to mate a carb to the EFI heads. The EFI heads are machined slightly different than the older carb heads.
Hammer Performance makes a billet manifold for a carb on EFI heads.
These manifolds are available either with or without the provision for the MAP sensor as used on 04-06 models.
