Can I still use my FP3 Fuelpak
Old Feb 25, 2018 | 02:37 PM
Justin727's Avatar
Justin727
Question Can I still use my FP3 Fuelpak
I have a 2015 HD Street Glide Special and currently use the FP3 Fuelpak. I am changing a lot of things on my bike and wondering if it will be possible to continue using the FP3.
At the end of my build the bike will be set up with:
Screaming Eagle Chisel Air Cleaner
Custom 2 into 1 exhaust (no o2 bungs)
Andrews 54H Cams
Big Boyz Street Heads
I do have o2 bypass plugs for my bike so the bike won't throw any codes.
I messed with the FP3 app on my phone in demo mode but couldn't figure out how to change the cams from stock.
What are your thoughts?
Thanks,
Justin
Old Feb 25, 2018 | 06:26 PM
Rocker B's Avatar
Rocker B
Andrews 54H Cams
Thanks,
Justin
You can edit for the 54H cams, go to view/edit maps, under "air/fuel", scroll down to "camshafts", the Andrews cams are listed... I'm not sure about the exhaust with no bungs and head work though. You should call V&H customer support and see what they recommend.
Old Mar 5, 2018 | 09:44 AM
Fireball Jack's Avatar
Fireball Jack
Can you sure, you can do whatever you want. Should you, No you need a good dyno tune.
Budda109
Jun 2, 2019 04:12 PM
kryingame
The Dyno Room
Oct 20, 2016 01:18 PM
J-S
Engine Mechanical Topics
17
May 23, 2016 02:14 PM
junglejoe
Dec 19, 2014 06:27 AM
surfnorthwest
Jun 29, 2014 06:56 PM
