Map sensor problem harley davidson touring 2011
Old Apr 27, 2018 | 08:04 AM
Andy Survivor's Avatar
Andy Survivor
Stage II
Default Map sensor problem harley davidson touring 2011
Im already change 5 map sensor after running 300 miles the map sensor was broke again .. Please help me
Old Apr 27, 2018 | 08:06 AM
bustert's Avatar
bustert
how are you determining it is a failed map??
Old Apr 27, 2018 | 08:10 AM
Andy Survivor
Stage II
I check the code is p107
Old Apr 27, 2018 | 09:39 AM
FLTRI17's Avatar
FLTRI17
Since you replaced the sensor and still get a fail code it appears you have a wiring issue.
Check the connector and wires for bad connection or break in the wire.
Bob
Old Apr 27, 2018 | 03:38 PM
bustert's Avatar
bustert
you can test the map with an ohm meter and vacuum source. not much can go wrong with them. if connected via hose, check it and via ported to manifold, check o-ring, any leaks will throw a code.
the tube is your friend when it comes to testing, easier to watch than explain, does not matter if it is on a diff vehicle.
once you know the map is good, mr. bob's answer is next.
Old Apr 27, 2018 | 06:45 PM
Ed Ramberger's Avatar
Ed Ramberger
Code means there is a problem in the circuit. You did not get 4 bad sensors in a row. Check all the wires - especially at the connectors for breaks inside the insulation. The insulation may be rubbery or stretchy when you pull on it.
Old Apr 29, 2018 | 12:26 PM
DayzedAndKunfoozed's Avatar
DayzedAndKunfoozed
was you clearing the code after replacing the sensor ?
Old Apr 30, 2018 | 07:36 PM
Max Headflow's Avatar
Max Headflow
You really need voltmeter and 5 volt source to check.. You can use the bike for the 5 volts and probe the output wire.
Add:
I agree with Bob and Ed. It's more than likely a wiring issue. Clean the contacts on the ECM connector.. Tug on the 3 wires going to the MAP sensor connector. If the map wires are routed certain ways the harness can flex and fatigue the wire.
Mild hog
11
Aug 8, 2021 01:16 AM
Johnboy1912
Jul 18, 2016 09:49 PM
Lee White
Apr 2, 2016 10:45 PM
danzio
Dec 27, 2014 12:35 PM
rigglemg
Dec 16, 2010 10:55 AM
