SEPST NEed a hand with tuning function
Old May 21, 2018 | 12:50 PM
edmroadglide's Avatar
edmroadglide
Default SEPST NEed a hand with tuning function
I have the black street tuner box, i know that the changes that can be made or pretty small but it does make changes and if a guy is going to use a canned map may as well get all you can out of the bloody thing. So my questions is this. Every time i go to the auto tune it asks me to load a base map first, in this case stage 2 with torque cams. It seems to do this every time though, does that mean every time you are wiping out the previous learned tune or tuned version and starting again? How can you tune on top of the tune you are working on? thanks for your help.
Old May 22, 2018 | 12:27 PM
FLTRI17's Avatar
FLTRI17
After you,have chosen a calibration to start with that cal must be installed into the ECM using the RECORD DATA tab.
Once you have done the SmartTune process you install the completed calibration using the PROGRAM tab.
So to recap:
1) Choose and install a calibration set to record data.
2) Ride the bike in all T/P and rpms possible using recording techniques (ie: using brakes and tall gears) to get to all desired cells for at least 5 eat and seconds each.
3) Process the gathered/recorded data per the instructions.
4) Repeat 1-3 until changes are minimal.
5) Ride and enjoy!
Bob
Old May 23, 2018 | 05:05 PM
shanneba's Avatar
shanneba
You might take a look at the HD Pro Street Tuner training, go through the "Tuning section" -
http://streetperformancetuner.harley...NU/index.html#
user 78082023840
Feb 5, 2018 08:10 PM
Max Headflow
The Dyno Room
Feb 24, 2017 10:56 AM
FLS103
Oct 20, 2014 07:00 AM
user 78082023840
Mar 29, 2013 10:29 AM
markwolula
Apr 29, 2012 06:57 AM
