Error Codes
Old Oct 24, 2018 | 02:26 PM
scotta13's Avatar
scotta13
Stage I
Default Error Codes
2017 Ultra Limited CVO 19,000 miles
I had several error codes come up:
U0001 - Vehicle CAN Signal Error
U0002 - Vehicle CAN Perf Error
What typically causes these codes?
Old Oct 24, 2018 | 05:55 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Typically a wiring issue unless you have added an aftermarket product onto the CAN buss.
Old Nov 1, 2018 | 10:57 PM
s8198's Avatar
s8198
Stage IV
I have a 2014 FLHX had A/c and d&d 2 into 1
i just installed Screamin' Eagle Twin Cam Tire Shredder Kit - 103CI to 110CIPart Number 92500038
  • Includes 4.0" cylinders, SE CNC-Ported Cylinder Heads, matching 10.2:1 forged high compression pistons and rings, SE-259 cams, perfect-fit pushrods, high-capacity roller tappets, cam cover gaskets, heavy duty clutch spring, high flow fuel injectors
  • Also includes the SE 58mm Throttle Body with high flow fuel injectors
using TTS to tune the closest I found to this build is EAE009-01 when trying to program pops an error “VIn Check 10”
so I went back to my last program and changed the ci injectors size and the cams but I was wandering what to do for the maps and VEs can I just copy and past them from the EAE009-01 file?
Nicholson1975
Engine Mechanical Topics
11
Apr 12, 2017 06:03 AM
pharough
Screamin Eagle CVO Models
Apr 7, 2015 10:14 AM
Boom
11
Sep 15, 2009 01:25 AM
mp99
Exhaust System Topics
Oct 2, 2007 08:45 AM
onlythebest
Jun 17, 2007 07:06 AM
