PC III Serial Cable:
Old Jul 3, 2007 | 01:24 PM
geargrinder's Avatar
geargrinder
Default PC III Serial Cable:
Does the serial PCIII use a standard serial cable to laptop? Just recieved a PCIII designed for serial comm from Ebay, but all documentation and cables are for a USB system, typical Ebay experiance. Sometimes companies change the serial wiring for more proprietory control. Thanks.
Old Jul 3, 2007 | 02:34 PM
Papamte's Avatar
Papamte
Default RE: PC III Serial Cable:
I have the PCIIIr model that uses the serial connector too. I found the cable I needed at Staples. I use my laptop to make changes or check the map, throttle position, etc. You can download the program and the manuals from the Power Commander website. Don't try to use the USB program because it only recognizes the newer units and the maps are in a different format. The older program will work just fine.
You'll need the serial to serial connector.
Old Jul 4, 2007 | 07:24 AM
geargrinder
Thanks, that's what I needed to know.
mulch63
Jun 21, 2010 06:37 PM
SokoDeployed
Jun 4, 2010 09:19 AM
anubisss
Jun 25, 2009 07:29 AM
Anthony8858
Jul 1, 2007 06:30 PM
WARG
37
Oct 28, 2006 05:29 PM
