Litttle Help Please
Old Jul 4, 2007 | 12:48 AM
NC_Biker's Avatar
NC_Biker
Default Litttle Help Please
Riding tonight and pressed the left turn signal to change lanes, when I did the Speedo died,Rpm died, Odometor died,no horn and the turn signals died. Whats the problem. I cant be the first this has happened too. thanks
Old Jul 4, 2007 | 02:03 AM
BGHV65's Avatar
BGHV65
Default RE: Litttle Help Please
You probably blew a fuse, check that first. If so, chances are you have a short somewhere unless it just popped the fuse for some odd reason. I had this happen on my UC when I used the lighter once. Didn't have a short, I guess it just overloaded the circuit long enough to blow the fuse but everything you said went out was the same as on mine.Hope this helps.........
Old Jul 4, 2007 | 07:32 AM
NC_Biker's Avatar
NC_Biker
it was the Accessories fuse. Possible it overload for some freak reason but not likely.I`m thinking the worst,a nicked wire some where from the fuse block out to each componet it feeds. Speedo,Horn,Turn Signal,brake light, what else does the accessories fuse supply etc.Since I pressed the left turn signal button and thats when it blew the fuse I would assume it was a short in the turn signal wires. If it happens again I`ll trace them out,maybe it want. thanks BGHV65 for your input.
Old Jul 5, 2007 | 11:58 AM
hernan's Avatar
hernan
Change the fuse, sometimes its just the fuse...
If it happens again, check the wires.
Long lonesome highwayman
Electrical/Lighting/Alarm
21
Apr 8, 2019 05:49 PM
bout3fitty
Jun 11, 2014 11:46 PM
JD211
Jul 19, 2012 11:45 AM
capttxrngr
Apr 8, 2012 04:49 PM
MANIAC SYLB
Aug 23, 2010 02:20 PM
