HELP!!! 2012 FXDWG starting issue
Old Feb 13, 2019 | 04:54 PM
ers66's Avatar
ers66
Stage III
Default HELP!!! 2012 FXDWG starting issue
Hi all,
I am having an issue getting my bike started.
When I push the start button, the engine cranks slow then stops after a couple slow cranks. I can jump my bike with my truck and it starts right up. After riding around it will start right up but after 12 hours or so of sitting it has difficulty getting going or it goes back to where I need to jump it again.
At first i thought it was my battery so I replaced it. But still Fresh out of the box and I am having the same issue. I have gotten a meter to read the output at start up and its amping down to 9.6 V. I have checked all wires and connections to the best of my ability (not great but as thorough as a beginner can be) and I didn't discover any wires that looked damaged or lose connectors. I haven't pulled the solenoid or starter yet. not sure i want to go that far just yet without someones opinion.
Any help would be great! thanks
Old Feb 14, 2019 | 12:08 PM
nevil's Avatar
nevil
Just because the battery is new doesn't mean it was fully charged when you took it out of the box. Put it on a charger overnight and try again. If not good then get it load tested. You should consider putting it on a battery charger when it's parked.
Double check to make sure the cables at the battery are good, and especially the ground cable connection- it needs to be clean and tight.
Old Feb 14, 2019 | 07:53 PM
hrdtail78's Avatar
hrdtail78
I haven't had the best of luck with any charger under an amp.
Old Feb 14, 2019 | 08:24 PM
ers66's Avatar
ers66
Stage III
I checked all the negative connection and grounds to the frame work. All look good. I have had. A trickle charger on the battery over night. Still won’t start with out a jump.
Old Feb 14, 2019 | 09:27 PM
Fireball Jack's Avatar
Fireball Jack
Trickle charger or Battery tender? There is a difference. The battery needs a full charge or replaced.
Old Feb 14, 2019 | 09:34 PM
ers66's Avatar
ers66
Stage III
I replace the battery already. Only a trickle charger. Even on the new battery. I did jump it a let it run for a good 15-20 minutes.
Javieret
EVO
22
Mar 4, 2019 08:13 AM
Heather Hradek
Aug 27, 2015 04:55 PM
Vic Bronco
Sep 21, 2013 12:07 AM
ranger007
General Topics/Tech Tips
Jan 23, 2010 08:26 AM
byrdi
Oct 8, 2006 01:07 PM
