Idle problems on a 2012 softail
Old Apr 7, 2019 | 09:03 PM
mikidd71's Avatar
mikidd71
Stage IV
Default Idle problems on a 2012 softail
Hi guys. I have a 2012 flstc harley. It has a high flow air filter, Vance and Hines pipes, and a screaming eagle tuner on it. When I first start it up, the idle will sometimes drop about 200 rpms for a second or so before coming back up. It will also do it when I pull the clutch in to come to a stop. It was happening a lot. I put some fuel cleaner in and ran 93 octane and it seemed to help a bit but did not fix the problem. Spark plugs were just replaced too, and they were burning good, tan coloured burn. Any ideas what else this could be?
Edit: Also, when the RPMS drop, and I try and accelerate, it is kind of sluggish, like it doesn't want to go. When it is over, it goes back to normal.
Old Apr 8, 2019 | 05:56 PM
mikidd71's Avatar
mikidd71
Stage IV
Bumbp
Old Apr 17, 2019 | 07:39 PM
jpowell490's Avatar
jpowell490
Sounds like you have a fuel pump issue.
BornScum69
Apr 26, 2019 02:06 AM
mikidd71
General Topics/Tech Tips
Apr 8, 2019 05:56 PM
soft 02
Apr 21, 2010 11:09 PM
jinxtre
Mar 23, 2010 08:08 PM
04NightTrain
Nov 20, 2006 08:40 PM
