no spark on front cylendar 98 electra glide
Old Jun 3, 2019 | 10:03 AM
larsfum's Avatar
larsfum
Trouble code 24 is Front Ignition Coil.
Old Jun 3, 2019 | 03:17 PM
bikermanusa1's Avatar
bikermanusa1
ok I put a new coil on the bike but when I checked center wire on plug not getting required voltage could that explain the same code coming up? I cleared codes and it came back
Old Jun 3, 2019 | 03:57 PM
Max Headflow's Avatar
Max Headflow
So the wire between the coil and the ECU is broke.
Old Jun 3, 2019 | 04:14 PM
bikermanusa1
ok I will look for that
Old Jun 3, 2019 | 04:15 PM
bikermanusa1
hey man thank you so much for helping me you are cool
Old Jun 3, 2019 | 05:45 PM
bikermanusa1
ok I think you are correct about that wire I took the cover off the plug to the ecm and the wire that matched the color of the center wire to the coil said its number 35 terminal now I have to find out if I am looking at the same wire from the coil I will try to find a chart with that plug on it when I turn the ignition on that wire gets 12 volt at the plug but not at the coil so I need to find this before I move forward of if you have that chart and can tell me if wire 35 is the right one that would help alot
Old Jun 3, 2019 | 06:46 PM
Max Headflow
Sorry, But I don't have a wiring diagram for that bike. The wire you seem to be talking about is the power wire. It's going to be one of the other 2 wires you are having issue with.. I don't know which is which.
Old Jun 3, 2019 | 06:52 PM
bikermanusa1
well the center wire is blue with 2 red stripes from coil same at ecm I think that's it but didn't want to replace it if was wrong wire
Old Jun 3, 2019 | 07:01 PM
bikermanusa1
ok let me get this straight the center wire should have 12 volts at the coil so that has to be the broken wire correct?
Old Jun 3, 2019 | 07:04 PM
bikermanusa1
because I don't have 12 volt at the coil center terminal when I look at same color wire at the ecm when I turn ignition on I get 12 volt at that wire
