Acceleration Pop
Old Sep 17, 2019 | 06:23 PM
Norris Rd's Avatar
Norris Rd
Default Acceleration Pop
I have a 2016 883 with 1250 conversion kit, joker machine air cleaner, and Roland Sands 2 into 1 exhaust. I also have an FP3 installed. I used high octane gas. The bike was running fine after these changes but after a while I developed a popping or burping during hard acceleration. I seems to come from the front of the bike. I have adjusted the tune many times (with help from Vance & Hines) and I have replaced the gaskets on my exhaust. Nothing I do seems to get rid of the burping/popping. Any ideas?
Old Sep 18, 2019 | 12:27 PM
nevil's Avatar
nevil
Even though you changed the exhaust gaskets you still should check for leaks where the exhaust sections are connected. Also check for intake leaks. It sounds like a fuel/tune problem but something like that can happen if you have poor battery connections at the terminals and also at the ground.
Check for codes as well.
Old Sep 19, 2019 | 11:56 AM
HotRod917's Avatar
HotRod917
+1 for the above post
Old Sep 21, 2019 | 11:27 AM
FLTRI17's Avatar
FLTRI17
Sounds like an excessively lean condition that needs to be properly addressed with a dyno tune...especially since you’ve spent time working with V&H and they haven’t cured the problem.
Bob
flstc15
Exhaust System Topics
Jan 16, 2018 09:16 PM
JPKaty23
11
Apr 23, 2015 08:33 AM
kjr2492
Mar 29, 2011 10:23 AM
Robert37
Sep 1, 2010 12:51 AM
WARG
Mar 11, 2006 08:19 PM
