Back fire???
Old Feb 24, 2006 | 03:44 AM
WARG's Avatar
WARG
Default Back fire???
After installing new pipes, SE A/C Kit, and having the dealer install the download. I have a minor back fire on deceleration. It is very minor but I notice it. It doesn't really bother me but I just want to be sure this is not going to cause any damage to the bike. What do you guys think?
Old Feb 25, 2006 | 09:45 PM
bluedog's Avatar
bluedog
Stage III
Default RE: Back fire???
The backfire is comming from cold air mixing with the hot exhorst gasses usually caused by an air leak in the system. fix the leak fix the bang
Old Feb 25, 2006 | 09:52 PM
went_postal's Avatar
went_postal
It seems like a common cause of leaks in the exhaust is the bolts not being torqued down enough at the exhaust manifold (or whatever it is called on a bike... Sorry... I work on cars.)
Old Feb 26, 2006 | 02:00 AM
ultravista's Avatar
ultravista
I'm having the same problem too after installing Vance & Hines Big Shots. Even with new exhaust gaskets, the bike pops and cracks on deceleration.
Maybe I need to tighten the nuts down a little more. I don't have a torque wrench so how tight should I go? Everything seems to be snug, no leaks when it's pushing the exhaust out.
While we're at it ... can a loose fitting exhaust contribute to poor fuel mileage? It seems that after the installation, my gas mileage went in the toilet. I've got the Power Commander III and the right (me thinks) map for my bike, air intake and exhaust.
Old Feb 26, 2006 | 02:18 PM
Mike05's Avatar
Mike05
As I see it: If you change things to get more air in and out of the engine you must richen the mixture with more fuel to avoid running too lean. More air plus more fuel equals better power but less fuel economy. I've seen posts where economy will drop from 40 MPG to 29 MPG after intake and exhaust changes. Better performance costs more than just the parts.
Old Feb 26, 2006 | 11:38 PM
Harley Al's Avatar
Harley Al
Maybe...you should of got the last year of the Carb?
Ride Safe!
Old Feb 27, 2006 | 12:30 AM
GrayRider's Avatar
GrayRider
You're too lean. The factory download is lean. The Big Shots are poor performers and are given to backfiring and popping. You're going to need a DFO to richen the mixture.
Old Feb 27, 2006 | 09:55 PM
monkyman's Avatar
monkyman
I've always heard a minor popping on decel is normal, as long as it's not on accel. I've heard harleys for years and years let off the gas and give off minor pops. Now a loud backfire is another story........
Old Feb 27, 2006 | 10:00 PM
ultravista's Avatar
ultravista
Yeah I would call this popping, not really backfiring. My pipes are tight and the gaskets are new so I guess I'll live with it.
Maybe a call to DynoJet will help.
Old Mar 11, 2006 | 08:19 PM
Tnicean's Avatar
Tnicean
ORIGINAL: GrayRider
I have Big Shot Staggered with quiet baffles, Ness Big Sucker and PCIII on my 2002 Heritage Softail Classic. No other mods. I am making 77 HP and 83 torque per the dyno. I wouldn't say they are poor performers. I get some gurgling and maybe a few quiet pops if I get off the gas completly after accelerating hard. I am happy with them.
Tnicean
aces&8s
EVO
43
Jun 28, 2021 04:52 PM
aaronmcb80
Exhaust System Topics
Nov 14, 2016 04:10 PM
Prologix
General Topics/Tech Tips
Aug 18, 2016 08:40 PM
ib5150
Apr 6, 2013 11:39 AM
rmodel65
Oct 13, 2007 07:57 PM
