Running bad
Old Oct 3, 2019 | 11:49 AM
Anthonym54's Avatar
Anthonym54
4th Gear
ok
will do
Old Oct 7, 2019 | 06:30 PM
Since 1968's Avatar
Since 1968
If not solved yet, there's a remote possibility that the 'tip-over sensor' (probably not the correct name) is loose or the mounting bracket is loose. With the sensor incorrectly positioned, maybe the difference in angle is shutting you down.
Old Oct 7, 2019 | 08:20 PM
Ed Ramberger's Avatar
Ed Ramberger
The bank angle function on the bike is in the TSM/TSSM and is either off or on. No middle road.
Old Oct 8, 2019 | 06:54 AM
Anthonym54's Avatar
Anthonym54
4th Gear
No tip over sensor on the 2006 dyna so im told. Bike was towed to the dealer yesterday even thow they normally dont work on bikes 10 plus years old!
Old Oct 8, 2019 | 08:00 AM
Since 1968's Avatar
Since 1968
Thanks for the correction Ed, once again I've shown a dangerous amount of knowledge.
Hey Anthonym54, I'm quite sure your '06 Dyna has a bank angle sensor. Had a friend stranded with his '04 Fatboy when his failed. Hard to imagine they would have a safety feature on just some models, or that they would go backwards between '04 and '06. However, as pointed out, it doesn't have an 'intermittent' failure mode. I hope your dealer can find it quickly. Intermittent problems can eat up a lot of time.
Old Oct 8, 2019 | 08:38 AM
Ed Ramberger
As stated in post 13, the Bank Angle Function is internal to the turn signal module
Old Oct 8, 2019 | 12:01 PM
Srh Goon's Avatar
Srh Goon
1st Gear
Default 07 fxdb running problem
Hey guys got my dyna went for a ride and started to loose power stopped and would not turn back on acted like it wasn’t charging so took it home and uncle jumped it with a running truck so I replaced tssm to tsm and a new ecm and the hole charging system with a new battery all married together... here’s the thing it’s a 96 conversion to a 103 and I got it running and I put it in gear and it dies right away or in neutral and I rev it it dies what to do next?
Old Oct 8, 2019 | 12:27 PM
FLTRI17's Avatar
FLTRI17
Sounds like the fitting at the bottom of the tank. It’s possible the o’ring inside the connection gets cocked or dislodged inside and restrict flow. Normally this occurs immediately. Disconnect the fitting and look up under it to see if the o’ring is still in place and not dislodged. If it is, remove and reinstall and you’ll be good to go.
Let us know,
Bob
Old Oct 8, 2019 | 01:43 PM
Srh Goon's Avatar
Srh Goon
1st Gear
Let us know,
Bob
Are u talking about mine?
Old Oct 8, 2019 | 02:12 PM
chopper_man's Avatar
chopper_man
You should start your own thread and done hijack someone else's.
