07 TPS sensor adjustment procedure
Old Oct 19, 2011 | 08:28 PM
tooldogg's Avatar
tooldogg
How did you get the inside Torx bolt out? Thanks
Old Oct 20, 2011 | 12:03 PM
iclick's Avatar
iclick
I took a Torx bit, the type that fits inside a small socket, and taped it to a box-end wrench. That's the only Torx option I had that would fit in that confined space. It was slow but it worked for me.
Old Oct 20, 2011 | 12:11 PM
soft 02's Avatar
soft 02
I recommend grinding a 1/4 off the end of the bit and using a wrench so the bit doesn't hit the fins when the screw is almost out.
Old Nov 6, 2013 | 07:49 AM
LoneWolf01's Avatar
LoneWolf01
I know this is an old thread but, I have been reading as many as I can due to have the same problem as most. Replacing the TPS seems easy enough except for the rear screw closest to the cylinder head fins. Can anyone tell me if they were able to install the TPS sensor with the throttle body still on or did you remove the throttle body and then replace the sensor? Also, is there any other tips or cautions for the procedure? Thanks in advance.
LW01
Old Nov 6, 2013 | 07:51 AM
soft 02's Avatar
soft 02
Piece of cake! Grind down the 1/4 bit and use a 1/4 wrench on it. Replaced my TPS several times. Got it down to a 15 min job.
Old Oct 9, 2018 | 12:05 PM
Mike07roadking's Avatar
Mike07roadking
Default 07 RK intermittent high idle problem TPS Code
Longest part of the job, grinding down the bit! Assume trick!
mulch63
Oct 31, 2008 10:51 AM
thomasf59
Aug 6, 2008 04:45 PM
thomasf59
Jul 28, 2008 05:55 AM
DPete
Aug 29, 2007 10:06 AM
MikesDad
Jul 25, 2007 01:45 AM
