Auto tune basic tuning
Old Oct 25, 2017 | 12:37 PM
bremerc's Avatar
bremerc
Default Auto tune basic tuning
I am new to tuning. I have the pv1. My bike is a 2012 street glide with a 103 and I just recently added Andrews 57h cams ,and a stage 1 big sucker. Dynojet sent me a stock tune and I want to do Auto tune basic. What is the process from here?
Old Oct 25, 2017 | 12:43 PM
jbarr1's Avatar
jbarr1
http://www.powercommander.com/downlo...utoTune.01.pdf
Old Oct 25, 2017 | 02:02 PM
shanneba's Avatar
shanneba
If you like youtube videos-
Power Vision's Auto Tune
What is Auto Tune
Old Oct 25, 2017 | 04:02 PM
bremerc's Avatar
bremerc
I have watched those videos. Good info. The manual helps a lot. So after I tune it the 1st time from my stock tune and export it, then I want to tune it again, do I chose the same one I just exported to Auto tune it?
Old Oct 25, 2017 | 05:52 PM
shanneba's Avatar
shanneba
Yes, after your Auto Tune session you will export the changes to a tune slot in the PV.
When you do another Auto Tune use the previous exported Auto Tuned Tune.
Remember to "Get" the tunes from the PV and save them to your computer in case you ever need to re-flash it.
Old Oct 25, 2017 | 11:14 PM
bremerc's Avatar
bremerc
Got everything in and started the by with the preconfigured tune. Bike sounded kinda rough. Is this normal until it adjusts itself with auto tune. Also, tried to load the tune that dynojet sent and it said I was missing a file to open and load it. Any ideas?????
Old Oct 26, 2017 | 09:42 AM
bremerc's Avatar
bremerc
Also, there is some backfiring and black smoke at idle.... HELP PLEASE!!
Old Oct 26, 2017 | 06:49 PM
KumaRide's Avatar
KumaRide
Yes, bike can run rough when in AT. Did you update WinPV then the dynojet map. The DJ map I was provided had some good things and some not good things. Where did you buy the PV? pm for more info.
Old Oct 26, 2017 | 07:30 PM
bremerc's Avatar
bremerc
I did the update and used a laptop to get the map from dynojet. I bought the unit from Dennis Kirk. They told me to contact dynojet. Lol. I found out my plugs are really black which tells me it running really rich right now. Hopefully the auto tune basic will fix it.
Old Oct 27, 2017 | 06:17 AM
shanneba's Avatar
shanneba
Did you update the PowerVision firmware?
If you connect the PV to your laptop, the WinPV software also includes an PV Update Client program. With the PV connected run that for any needed updates.
Maybe the Tune Dynojet sent needed a newer firmware version. That may have been the error message you got.
