Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
What should the values on the autotuned maps look like. Mine are all over the place when I look at them. I don' really know what I'm looking at but.....
The first mistake here is thinking that "Auto Tune" is actually "tuning" your bike. It doesn't. Thinking that "Auto Tune" will make all the necessary changes for new cams and intakes "automatically"? Not likely. The PV is a tool. Understanding what the tool can, and cannot, do is important to using it effectively. "Auto Tune" is primarily an attempt to calibrate the VE tables. That's it. Well at least on Sporty's. On BT's - if I remember correctly - it''ll take advantage of the knock sensors and make some (minor) timing adjustments.
Sounds to me like you need a map that's been created for the changes you made (or that is pretty close). I might call Jamie at Fuel Moto. He might have what you need and might be able to guide you through.
Otherwise you might want to find a competent/professional tuner.
How do you do a data log from the gauges screen? Will it save when you are done?
You need to setup your datalog signals, the same screen as Gauges, choose datalog settings, then signals, choose manual and add the signals you want to log.
You can do this connected to the computer, choose PowerVision from the WinPV menus, Choose Diagnostic / Test Functions, then Exit PC Link Mode.
You will see your PV screen and can move around the menus. You can't do anything that requires a connection to the ECU like Program or clear codes etc.
Then on the Gauges, choose "Start Log" at the bottom of the screen.
(it will also log the signals you select on the gauges if you didn't already select them for manual)
