Rear cylinder not firing
Old Oct 17, 2019 | 03:50 PM
toybox bikes's Avatar
toybox bikes
Stage I
Default Rear cylinder not firing
Gents, I've seen/read a few posts on this.
Bottom Line: Rear Cylinder is not firing (2008
Code=P1355 Rear Ignition Coil Driver high/shorted
what I've checked and is good to go: - spark plugs, spark plug wires, Coil (ohms), power to coil, replaced crank sensor, injector good to go.
What I will check tonight: molex connection for crank sensor
Old Oct 17, 2019 | 03:52 PM
pgrchaplain's Avatar
pgrchaplain
Borrow a Coil and see if thats the Fix.
Old Oct 17, 2019 | 08:17 PM
FLTRI17's Avatar
FLTRI17
Swap the wires and you’ll know if it’s the coil. It won’t run very well if at all but you will know.
Bob
Old Oct 21, 2019 | 10:41 AM
Max Headflow's Avatar
Max Headflow
Bob
If he swaps plug wires, he'll also have to swap the primary wires to get the bike to run.
My guess is that either the rear cylinder primary wire is shorted to the coil power wire or the driver circuit in the ecu is toast. (or both)
D-Bag
Engine Mechanical Topics
Jul 17, 2014 09:21 AM
stellar
Aug 24, 2012 12:21 PM
SgtMic
Sep 7, 2011 07:32 PM
n.texan
Ironhead
Jun 21, 2011 09:33 PM
D-Bag
Electrical/Lighting/Alarm
Nov 13, 2010 08:45 AM
