Map for Super tuner pro
Old Dec 6, 2019 | 08:50 AM
2slow05's Avatar
2slow05
Default Map for Super tuner pro
So i am about to install a set of 255 cams into my 2008 ultra, its a stock 96ci with true dual rineheart exhaust, and se air cleaner. I am going to use my super tuner pro that i have on it right now to tune the bike. I have downloaded the program and purchased the cables. What i am looking for is a baseline map that i can start with then datalog and go back and make changes. My problem is i dont see any 96ci with exhaust and 255 cams on it. Does anyone know what baseline map i should start with? I would really like to try and get it dialed in by myself instead of taking it to a dealer and having them dyno tune it for $400. Thanks in regards
Old Dec 7, 2019 | 05:51 PM
Ed Ramberger's Avatar
Ed Ramberger
205uh005
Old Dec 7, 2019 | 05:57 PM
2slow05's Avatar
2slow05
Originally Posted by Ed Ramberger
205uh005
thabks i I appreciate it. I will look at it when I get to a computer. Did you tune one with it ? How close was the map? And what was it on?
Old Dec 7, 2019 | 06:14 PM
Ed Ramberger
No - you asked for a map and that is the closest on the tuner. It's for a 103 so just set the engine size to 96.
Old Dec 8, 2019 | 04:54 PM
2slow05's Avatar
2slow05
how do you set engine size to 96 ? With a 103 map
Old Dec 8, 2019 | 06:46 PM
FLTRI17's Avatar
FLTRI17
Just start with the 103 map. You’ll be fine.
Bob
Old Dec 8, 2019 | 07:12 PM
2slow05's Avatar
2slow05
Bob
i found one it’s 358sdx002.dto it’s for a 12-15 softail/Dyna and 2016-2017 Dyna. It’s a 1580 (96) stage 2 kit, with se exhaust, air cleaner and a 255 cams. The only thing about that one is it shows ACR on. What’s your thoughts on that one?
Old Dec 9, 2019 | 02:17 PM
FLTRI17's Avatar
FLTRI17
Must be a 205 calibration. Ed gave you what you need to know.
Starting with the 103” calibration will be fine, and maybe a bit better if you have low restriction, open exhaust.
Bob
Guzz
2014-2024 Touring Models
30
Sep 25, 2022 04:47 PM
sgr60
The Dyno Room
Oct 10, 2017 05:53 PM
twincam_tim
Jan 3, 2016 03:27 PM
HDSAE60
Feb 19, 2015 01:09 PM
oldgraybeard
Jun 16, 2009 05:11 AM
