thundermax, and cams
Old Jul 19, 2007 | 08:25 PM
gpp's Avatar
gpp
Default thundermax, and cams
have a 07 rk with wildpig slip ons and se aircleaner with a pc111.i plan to get a andrews 37 cam and maybe some minor head work.will the thundermax compensate for the changes automaticly without a dyno?
Old Sep 30, 2007 | 01:46 AM
Yardstick's Avatar
Yardstick
Default RE: thundermax, and cams
It will take care of the A/F ration offset with the new air flow. However, if the cams need different timing to make the best power...you will need to talk to someone who is familiar with the cam and it's timing requirements.....then you can go in your map and adjust accordingly.
Old Sep 30, 2007 | 08:29 AM
Harleypingman's Avatar
Harleypingman
IIRC, Zippers maintains a list with maps for a large number of engine configurations. You find the map that is the same or closest to your engine/exhaust and load that map into the Tmax with Auto-tune.
MisterSlim110
Nov 19, 2019 08:08 PM
barrygreen
Engine Mechanical Topics
Oct 5, 2019 04:16 PM
roussfam
Mar 20, 2016 06:45 AM
Gater
Aug 3, 2015 02:57 PM
msr082881
Feb 20, 2015 04:28 PM
