Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Well I paid up and used it. My Smart Tune wasn't out by much. 10% max in a couple of cells. Went for a 3hr ride, throttle seems more responsive and smoother? Kind of hard to explain. And for some weird reason bike seems a little quieter, mellower, when I get on it. All in all, I give it a thumbs up and worth the $29.99
Jim
Interesting. Did you have any pings/knocks that you could hear and did mytune correct these? I have addressed knocks using PV and data logs. Manually going through logs then changing values with PV.
None that I could hear, but MyTune picked up a few events and retarded the timing in a couple of cells. Just copied everything back into the appropriate Super Tuner tables, saved and reloaded the map to my bike.
If I had to sum it all up, MyTune takes the results from your tuner smart tune/auto tune session and fine tunes/tweaks it a little further.
Seeing how it works on tables from a variety of different tuners and only costs $30, it's a no brainer. Especially considering the $$ spent on a tuner in the first place.
