Screaming Eagle Ignition Tuners
Old May 12, 2020 | 10:22 PM
Robert Hanlon's Avatar
Robert Hanlon
Default Screaming Eagle Ignition Tuners
I’m looking at SE parts 32124-04A or 32124-04B for adjusting the ignition on my 05 883r. I’m going to put w cams in and eventually do a big bore kit. I can’t find much information on these tuners, any thoughts on how to use them or what maps are on them would be much appreciated.
Old May 12, 2020 | 10:36 PM
Tommy C's Avatar
Tommy C
Change the cams when you do the 1200 conversion or you'll be buying 2 sets of cams. Punch it out to a 1200 or 1250, bump the compression, port the heads, and install the proper cams and the bike will haul ***. Save your money and do it all at once and you won't be sorry. I can't tell much about those SE tuners but If I were you I'd buy a Dynojet Powervision tuner and have your bike tuned on a dyno.
Old May 13, 2020 | 06:06 AM
BuzzCap7's Avatar
BuzzCap7
Hi there Robert, I moved your post to the proper area. You will likely get some GOOD replies here in addition to what Tommy said above. Pls see below. Have a GOOD day mate.....
Superfly3176
Mar 21, 2011 05:20 AM
hd2000heritage
Jan 9, 2010 11:26 AM
thedonthere
Nov 30, 2009 06:50 PM
virtualmike13
Oct 3, 2007 04:13 PM
richb
Mar 30, 2005 10:15 AM
