brake lights issue
Old Jun 10, 2020 | 11:12 AM
tin sandwich's Avatar
tin sandwich
Default brake lights issue
i have tail lights but no brake lights . neither the front or rear switch works. or the brake light may be stuck on. i cant tell. i do know that both terminals red and orange at the rear switch are both hot with key on as is both contacts inside the bulb housing. this leads me to believe the brake light is stuck on. im no electrical person. can anybody lead me through some troubleshooting?
Old Jun 10, 2020 | 03:47 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Disconnect the wires from the rear switch, does the light go out?
If it does not go out, the problem is the usual suspect, the front switch...
Very Important:
Tell us what you are working on...
Old Jun 10, 2020 | 04:59 PM
tin sandwich
thank you dan....its good to have you guys here.i did disconnect both wires and light did stay on.i then disconnected brake lever and worked switch back and forth. you were correct .brake lights again. i dont know what happened.i sprayed some electronic cleaner on it. i think im good to go. much thanks.
Old Jun 10, 2020 | 06:20 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Sometimes the front switches get crudded up and just need a shot of cleaner or lube.
Ranger12s
Shovelhead
Sep 30, 2017 08:27 PM
MontanaRider
May 18, 2013 12:02 PM
coopaloop108
Nov 30, 2012 09:43 AM
hdmatt29
Oct 4, 2011 10:03 PM
Wrongturn
May 13, 2009 01:20 AM
