Can this cause a decel pop?
Old Jul 24, 2007 | 06:41 PM
TickTock's Avatar
TickTock
Default Can this cause a decel pop?
Found this while replacing the TP sensor (for fun)...
[IMG]local://upfiles/24326/04714A6B26764C6C8445BFADF3C24261.jpg[/IMG]
[IMG]local://upfiles/24326/6254D8A690894BC090F900808D81600B.jpg[/IMG]
In two days when the replacement arrives, I will know the answer. I'll keep you guys posted.
Old Jul 26, 2007 | 06:20 PM
TickTock's Avatar
TickTock
Default RE: Can this cause a decel pop?
No such luck!!!
What about a crank position sensor? If it is acting up would there be a pop in decel during say a steady 2800 rpm and a complete throttle roll off? Also the downshift pop? Both happen when the bike gets hot(old readers tired of my problems know I've done the decel enleanment thing and had it professionally dyno tuned). I have also had the bike do weird rpm things such as drop down to 750 on the tach when I stop - then I go for another mile and stop and the bike just quits. A few times when the bike is hot it has gone up to 1250 on the tach and stayed for several seconds. No codes...
Old Jul 28, 2007 | 03:26 PM
TickTock's Avatar
TickTock
Well it turns out the CKP was bad. However it slightly helped the problem. Still searching for an answer...
Old Jul 29, 2007 | 05:47 PM
jmetro's Avatar
jmetro
Decel pop is caused by a lean condition. richen up your 0% throttle settings and it should go away.
Old Jul 29, 2007 | 06:41 PM
TickTock's Avatar
TickTock
I hopefully have made some progress by smoothing out the values between 0, 2, 5 and 7 throttle position. I removed the dump of fuel that was in the map at zero and it seems to have relieved the decel pop on downshift. I need more testing, but the add fuel thing seems to not work in this instance. I think it is because the transitions are too great when you are at around 5-7-10 throttle position in the 1750 - 3000 rpm ranges.
I started by getting my wife to ride on the back and made a data recording. I held the throttle steady for 10 seconds at 2200, 2600 and 2800 through each gear to determine what the throttle position was normally. Once I had the data I analyzed it to see which ve tables were being called at each throttle position. I then worked through the smoothing I mentioned earlier to help make a good transition in the zero throttle position during the downshift process.
I still have the pop on throttle roll off at 2800 and 2600 but I think I canwork through it. If at a minimum I have rid myself of the annoying downshift pop I will be happy.
Example VE Front
Before
0%2% 5% 7%10%
1500 104.0 90.5 81.5 81.580.0
1750 104.0 90.5 89.0 82.584.5
2000 104.0 90.5 88.5 78.579.5
2250 106.0109.5 85.5 78.080.0
2500 106.0109.5 87.0 74.580.0
2750 104.0111.5103.080.085.0
3000 104.0109.5103.0 77.585.5
After
0%2%5% 7%10%
1500 80.580.581.581.580.0
1750 85.587.089.082.584.5
2000 85.586.088.578.579.5
2250 85.584.085.578.080.0
2500 86.086.087.074.580.0
2750 87.087.088.580.085.0
3000 87.089.591.577.585.5
D W K
Nov 28, 2015 11:47 PM
cgptv
Oct 7, 2015 12:10 PM
Robottom
Jun 16, 2015 08:56 PM
cuda67bnl
Apr 12, 2011 07:20 AM
newbiker
Jan 27, 2010 10:07 AM
