Starter only clicks
Old Aug 7, 2020 | 03:38 PM
IBE's Avatar
IBE
sounds to me like a new starter is in line. but take the starter off and test it,very easy to do.
Old Aug 7, 2020 | 04:03 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Maseo:
Don`t go out and buy a starter....
Put your voltmeter probes on the battery posts, then press the start button.
What does the voltage read while the button is pressed?
Old Aug 8, 2020 | 12:39 AM
MASEO FLORES's Avatar
MASEO FLORES
3rd Gear
So the ****en bike started this afternoon and has been firing every damn time... IDFK. I’m gonna try to see if maybe I have some parasitic draw somewhere. I don’t trust it to drive 50 miles to work everyday again. It was at 12.87v before I started it and dropped to 12.66v once I shut it off. I started it again and the voltage showed 14.02v while running at the terminals. It’s on a trickle charge right now. I’ll take it off when it’s green and check the voltage throughout the day.
Old Aug 8, 2020 | 09:23 AM
Max Headflow's Avatar
Max Headflow
Mote than likely it's not the battery. It's the control wire going to the solenoid or the solenoid itself. It takes a few amps to pull the solenoid in. If the connection is poor you'll get the click but no action. Another issue can be that you dropped one of the coils in the solenoid. There are 2, A pull in and an hold in. In either case, the solenoid does not pull in far enough to engage the contacts but clicks. If you tried the jumper method and it didn't work one of the coils could be open.
Old Aug 8, 2020 | 08:57 PM
EVOrider's Avatar
EVOrider
Originally Posted by Harley1004
YOU would not expect it, but corroded wires I have seen. Run a volt test from battery ground to the ground wire under starter. Place one test lead on batt ground and one test lead to ground wire under starter while you have meter on 20 vdc setting. with engine on hit the starter switch and see if you have any voltage reading on meter ground to ground. If you read any voltage between batt ground and basically engine ground, you need to find the ground connection that is bad. I think this may be the problem. This is called a reverse voltage drop. If the meter reads more than .5 volts dc, you have found your problem
I second that as well.....seen it a few times myself.
BubbaFLMC
Shovelhead
May 6, 2019 07:47 PM
marktruckee
EVO
Feb 24, 2016 07:20 AM
Donn 86 flhtc
Mar 4, 2015 07:42 PM
genokelly
Engine Mechanical Topics
Aug 30, 2014 07:54 PM
95yj
EVO
14
Jun 13, 2012 06:34 AM
