Weird starting issue????
Old May 4, 2021 | 03:55 PM
Bleysaway's Avatar
Bleysaway
5th Gear
Any luck on yours?
Old May 4, 2021 | 04:28 PM
marcodarq's Avatar
marcodarq
next thing to look at would be the crank sensor,,,,,sometimes they go intermittent when they begin to fail. more obvious at lower cranking speeds.
m
Old May 4, 2021 | 04:37 PM
MURPHCC1's Avatar
MURPHCC1
to the ones that are having the problem now........
Check INSIDE your fuel tank when you turn on the ignition......
See a fuel spray going on in there?
Thats a pinhole leak on a high pressure line in there, it rubs against one of the braces. it lowers the fuel pressure JUST enough to not start......
I had the EXACT same problem as the OP..........changed out the hose and the feel filter in there and never had a problem again.
Re route that high pressure line when you're in there so it doesn't rub against the brace.
There are other threads about this exact issue.........
Old May 5, 2021 | 11:02 AM
jory434's Avatar
jory434
I am losing spark on start-up when the problem occurs. Keeping an eye on this thread for findings of others
Old May 6, 2021 | 06:32 AM
60Gunner's Avatar
60Gunner
Unfortunately there's no way to test the ECM short of trying another one.
Did you check the coil with an ohm meter? I don't recall the specs but should be in the manual.
Old May 6, 2021 | 06:39 AM
Bulrid8's Avatar
Bulrid8
Mine ended up being using comp eliminator sprocket with the easy start cams. It was turning engine to fast to detect compression. Once I switched back to a compensator, started fine since then.
Old May 6, 2021 | 06:41 AM
Bleysaway's Avatar
Bleysaway
5th Gear
Default Looks like it’s the ecm found a short under seat
5v wire grounded to Frame repaired it have replaced crank sensor coil is good little more testing today then pull the trigger on ecm bypassed the tsm and still no spark so it’s good going to double check the harness today have it all pulled out so check and check again lol
Old May 6, 2021 | 08:58 AM
jory434's Avatar
jory434
I am having this problem after I changed to a Darkhorse Compensator. I also found that my front plug wire wont ohm consistently. Definitely a bad wire, but if new wires dont fix my problem I may going back into the primary. I will report my findings.
Old May 8, 2021 | 02:13 PM
jory434's Avatar
jory434
I went back to a stock compensator this morning. I let the bike sit for 2 hours and told myself I wasn’t gonna touch it till tomorrow. Well I couldn’t Stand it. It just started 20 times in a row
I can’t explain it but glad it’s starting again
Old May 9, 2021 | 07:24 PM
CarlosGGodfrog's Avatar
CarlosGGodfrog
A voltmeter is your friend. If the Battery voltage drops into the 9s or even the 8s, the starter will crank, but the ign might not fire. A quick charge will give a surface charge to start it up.
