Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
And you apparently think that what you post is the final word.
well, that was a Delphi guy that knows his ion sense better than you or anyone else here. The ion sense was designed to work with a wide Nothing special about the stock champion plugs but run em if ya want. The NGKs work just as well if not better. Quit telling people they don't. Jeezus
i haven't seen a knock event yet and I've tried making it knock.
I think this Delphi engineer knows his own ion sense circuit better than anyone here. It would appear some of you think otherwise or are just flat out making **** up to support your view on using the stock plugs and stock everything else most likely. But as far as the stock champions, it's not really about the cost so much as just being champions. But if others run them and/or like them that's their business. Just tired of hearing this same old bs rumor every time someone mentions NGKs.
Originally Posted by glbsportster Interesting reading from a Delphi Engineer...
Regarding the OEM Champion plugs the resistive element that they use is not a resistor; it is a semiconductor suppression element. The effective resistance is specified to be 6k-15k. Furthermore, there is a fairly strong negative temperature coefficient, so the resistance decreases at normal operating temperature. In my experience, I have typically seen it in the range of about 2k-5k when the engine is running.
Note: Because the suppression element is not a resistor, it cannot be reliably measured with a conventional ohmmeter. The resistance of the element must be measured in an apparatus that provides 1000V pulses (per conversation with a Federal Mogul engineer).
You made it clear that this is all the information you wanted. However, if you want some insight into the ion sense system and related trouble codes, you may read on.
With regards to ion sensing, there is absolutely nothing magic about the Champion suppression element. Any trouble codes that you encounter have nothing to do with the resistance of the spark plug. Our circuit is designed so that we can tolerate a very wide range of resistances. We can easily operate with spark plug resistances from zero to 20k.
The ion current that we measure is in the range of 0-50 microamps. To avoid ion sense related trouble codes, you must have perfect continuity from the ignition coil to the spark plug tip. We have trouble codes P1353 and P1356 (front and rear cylinder, respectively) that are detected if we see no ion current under high speed/load conditions (where the ion current should be strongest). These codes will detect an open circuit in the ignition secondary circuit.
Additionally, we have trouble codes P1357 and P1358 (front and rear cylinder, respectively) that are detected if we see excessive noise on the ion signal. The intention of these codes is to detect an intermittent terminal.
there are diff sense circuits and diff engine parameters. these must be matched up in order to collect data.
high resistance within parameters of design offer little to no detrimental effects to the ignition.
i would say spark plugs are lesser of an evil because if the mix is correctly lit off, the ion sense will work. all ion sense is a parallel voltage that is sent through the flame kernel which is measured and used by the ecu. where you get into trouble is with the coil, why????
well some coils form a low pass filter which will not allow this data to pass through.
I wholeheartedly concur. As a trained motorcycle mechanic I was advised to stop using champion in the '70s , with reason. AC (Albert Champion) iis not any different..
So, some guy told you not to use a certain product, over 40 years ago.
As a trained (and FAA certified) aircraft and powerplant mechanic for over 40 years, and over 50 years working on simple stuff like cars and motorcycles, I have never been advised to avoid any brand of spark plug by anyone, except of course reading stories on the internet.
Reminds me of a tired joke from back in the late `70s
"If Harley Davidson made an airplane, would you fly on it? "
thanks for all the replies guys. I may go back to the DCPR7E, as it seemed a little snappier than the 6r12......But I must admit my experience, that the 6r12 seems to have a smoother operation all the way around then the DCPR7E.... Just Saying
