Map vs. Dyno
Old Nov 21, 2020 | 03:42 PM
ral819's Avatar
ral819
Default Map vs. Dyno
I'm trying to get a handle on the tuning variables out there and have a couple questions. If you have an Smart tuner, or Auto tune type of a Tuner (SE Smart Tune Pro, FP3, Powervision, etc), would you still need to Dyno tune ? I know a "canned map" can be installed which covers AFR , correct ? Does Dyno tuning provide a more "detailed Map" which is more sensitive to the AFR. I'm confused as to my situation. I have a 2018 RGS with a SEST and SE Smart Tune Pro. Why would I Dyno when a basic Map could be installed. (Also , I have wide band sensors with this Tuner). By the same token, A Powervision or FP3 tuner using a "narrow" band O2 sensor, will they benefit from a Dyno tune, more so than just a "canned Map" ? Am I correct in believing that the Auto tuners adjust for current running environment, MAPs are either basic tuning AFR's, or detailed AFR's from a Dyno tuner ?
Old Nov 21, 2020 | 05:39 PM
chopper_man's Avatar
chopper_man
Depends on your mods. A good dyno guy can bring the most out of the bike. For basic stage 1 stuff, canned tune is fine.
Old Nov 21, 2020 | 05:48 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
A Tuner module can certainly get you pretty close to the optimum parameters for the engine's needs but a good Dyno tech can nail it! IOW's, there's no replacement for a dyno tune.
vonh12's Avatar
vonh12
If your going to make more changes to your bike skip the dyno tune for now. Canned tune with auto will get it close.
When your done upgrading dyno will give optimum results, with a good dyno/operator!! But it's not cheap.
Old Nov 21, 2020 | 07:48 PM
roussfam's Avatar
roussfam
Oldie but a Goldie
Old Nov 21, 2020 | 08:13 PM
60Gunner's Avatar
60Gunner
Originally Posted by roussfam
Oldie but a Goldie
Not even old. Same question asked 5 threads down.
Old Nov 21, 2020 | 10:14 PM
roussfam's Avatar
roussfam
You're right, lol. Didn't notice
Mr. Wizard
Aug 31, 2016 08:19 AM
1plumr1
Aug 31, 2014 02:26 PM
markwolula
Apr 29, 2012 06:57 AM
rshwetz
Feb 7, 2010 01:06 PM
kazanimo
Oct 25, 2009 08:25 AM
