Hard to start cold/ check engine light
Old Mar 7, 2021 | 04:00 PM
Budman88's Avatar
Budman88
1st Gear
Default Hard to start cold/ check engine light
I have a 2001 Electra Glide Classic recently the check engine light keeps coming on then goes off not dropping any codes in the instrument cluster. Now the bike has been hard to get started when cold ( restarts just fine when bike is warm ) when I do finally get it started the check engine light is on and stays on for 10 to 12 miles then goes off. It used to fire right over no problem touch the starter and it would start now it takes multiple times to get it started.
Thanks in advance for any feedback
Old Mar 7, 2021 | 04:20 PM
MyFavRk's Avatar
MyFavRk
First off , get your battery load tested , most shops will do it for free , just charging it won't help if you have a weak or dead cell ,
You say that your not getting any error codes , the temp sensor , when it starts to go will do that , could try replacing that and see if that fixes the issue . I don't usually just throw parts at a bike , but this one sounds like it could be the issue . The crank sensor is also the same way , rough start / idle etc , no code .
I would also think Idle speed actuator or fuel pressure , but you say it starts and runs fine when warmed up , thinking out loud here .
Old Mar 7, 2021 | 08:13 PM
Ed Ramberger's Avatar
Ed Ramberger
2001 doesn't report codes on gauges - you have to use a jumper wire to pull them out if you don't have a scan tool.
Old Mar 9, 2021 | 05:44 AM
Budman88's Avatar
Budman88
1st Gear
Thanks I replaced the temp sensor last year, will get battery checked & crank sensor. Thanks again for the info
Old Mar 9, 2021 | 06:03 AM
MyFavRk's Avatar
MyFavRk
While your at it , get yourself a can of electrical contact cleaner . Check your connections , fuse box , relays etc , corrosion is your enemy and can cause all sorts of electrical issues . Pull your main fuse , then unplug each item one at a time , spray and let dry .
As Ed stated , you can pull your codes using a jumper , have you checked to see if any come up ? When your red light comes on , it should have stored an error , you would think .
Old Mar 10, 2021 | 09:22 AM
Zanthamos's Avatar
Zanthamos
2001 has no main fuse, main CB on that model.
Old Mar 10, 2021 | 12:21 PM
MyFavRk's Avatar
MyFavRk
Thanks Z , I still have a lot to learn , especially if I want to help others on the forum , I appreciate you coming in and correcting me , that's what it's all about .
Rickey
Oct 16, 2012 05:56 AM
lkr0
Aug 23, 2009 06:24 PM
caorig
Mar 30, 2008 08:49 PM
calacha
May 31, 2007 07:34 PM
PLHOG
Apr 23, 2005 07:05 PM
