Misfire - Backfire
Old May 12, 2021 | 01:52 PM
pcan's Avatar
pcan
Stage II
Default Misfire - Backfire
I have a 1998 Softail. I had a 30,000 mile tune-up done at the end of last year. Drove great coming home. Sat for a couple months during the peak of winter. Started riding again periodically in March. When I start it up, it idles fine. When I take off, it seams to misfire/loose power intermittently and then back fire nearly every deceleration. After riding for about 5 minutes or so, it operates perfectly. I have let it completely warm up before taking off and still has same issues. Have checked everything I can think and have drained the fuel. Local dealership seems dumbfounded as well (Not super impressed with the Fishers IN Service shop). Could sure use some additional ideas of what to check
Old May 12, 2021 | 03:59 PM
marcodarq's Avatar
marcodarq
check for vacum leaks....and report back with what you find.
m
Old May 12, 2021 | 06:43 PM
MyFavRk's Avatar
MyFavRk
Could try running some sea foam in the tank , 1 ounce / gal , clean the tb really well , both butterfly and seat , and check the air cleaner .
Old May 14, 2021 | 12:33 PM
60Gunner's Avatar
60Gunner
Edited because I have CRS.
Old May 19, 2021 | 12:04 PM
pcan's Avatar
pcan
Stage II
Thank you for the input. Ended up needing a new slow jet. Beast was wanting more petro!
Old May 19, 2021 | 01:25 PM
MyFavRk's Avatar
MyFavRk
Glad you got it sorted out , nothing beats a fine tuned machine , enjoy !
rhlhamlet
Mar 2, 2014 12:03 PM
Rampant
May 27, 2013 09:15 AM
tbell
Feb 1, 2013 09:02 AM
beatmasterspeech
Sep 22, 2010 03:17 PM
simoneales
Feb 9, 2010 04:16 AM
