died, no start
Old Jul 12, 2021 | 01:11 PM
JerzyDog's Avatar
JerzyDog
Stage III
Default died, no start
2009 Road King.. left the garage, pulled up to the end of the driveway and it died. Cranks fine, no start. Has codes P1511, P2101. I checked all the electrical connections, seemed secure with no obvious issues. It will fire with a small shot of ether, so I know it has spark, seems to be not getting fuel at all. suggestions on where to go next?
Old Jul 12, 2021 | 08:04 PM
MyFavRk's Avatar
MyFavRk
Is the fuel pump priming when you turn the ignition on ? Any work done recently ?
Welcome to the forum , head on over to the welcome area and introduce yourself , lots a great guys / gals here , as well as great information .
https://www.hdforums.com/forum/welcome-area-only-4/
Old Jul 12, 2021 | 08:11 PM
MURPHCC1's Avatar
MURPHCC1
Welcome aboard from Old Cape Cod!!!
Old Jul 13, 2021 | 07:19 AM
JerzyDog's Avatar
JerzyDog
Stage III
yes, you definitely hear the pump prime when turning on.
Old Jul 13, 2021 | 07:31 AM
MyFavRk's Avatar
MyFavRk
Good news there , open your gas cap , 1/2 tank of fuel or close , turn the ignition on and listen for a " spray " , could be a leak in the fuel hose or cracked / faulty pressure regulator .
If your bike hasn't had a new fuel filter installed , I recommend pulling the pump and changing all three , hose , filter and regulator , depending on miles , it's probably due .
After that , clear your codes and test it , hopefully that's all it is .
Old Jul 24, 2021 | 05:39 PM
JerzyDog's Avatar
JerzyDog
Stage III
FYI... it was a bad pressure regulator.
Old Jul 24, 2021 | 06:02 PM
MyFavRk's Avatar
MyFavRk
Glad to hear you got it fixed !
Now go make up those lost miles , congrats !
sebe4848
Jun 29, 2021 11:00 PM
Coca450
Sep 2, 2018 11:17 PM
HOGDAT
EVO
Dec 7, 2014 06:38 AM
nitros
Apr 2, 2013 05:45 AM
mcgehee1946
Exhaust System Topics
Jul 21, 2005 12:46 AM
