98' flhrc efi no fire???
Old Dec 6, 2014 | 11:43 AM
HOGDAT's Avatar
HOGDAT
Default 98' flhrc efi no fire???
Help! Got a 98' FLHRC EFI that was running one minute, turned it off, refueled & now won't start. Tried spraying a little quick start in throttle body & nothing.
I can hear the fuel pump activate when I turn ign on, but then it cranks & cranks but won't start.
What's ya'lls gut feeling on this one? Thanks.
Old Dec 6, 2014 | 12:36 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Default Got spark....
The next thing would be to check for spark....
Old Dec 6, 2014 | 04:06 PM
HOGDAT's Avatar
HOGDAT
Just walked out & it started right up. Crazy!
Had no spark yesterday when trying to start it then today it decided to fire right up. Temperamental son of a gun isn't it!
Old Dec 6, 2014 | 04:15 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Was it raining when the bike wouldn't start?
If your coil has a small crack and water gets in it you will loose fire.
Just a thought.
Old Dec 6, 2014 | 09:34 PM
1997bagger's Avatar
1997bagger
Ignition module in nose cone failing, they are known to start melting and oozing fluid out of them in M&M EFI after some years
Old Dec 6, 2014 | 10:13 PM
SeaZund's Avatar
SeaZund
I hate troubleshooting those intermittants that fix themselves
Old Dec 7, 2014 | 01:20 AM
Rhino-1's Avatar
Rhino-1
I'd also check the crank position sensor. Had a similar situation on my Springer and it was the CPS...
Old Dec 7, 2014 | 06:38 AM
im's Avatar
im
CRANK POSITION SENOR...the connector...Throttle side...under plastic painted cover...under seat...triangle frame area...connector gets loose.
or
the cam sensor is melting..timer cone area by foot..see melted goo at bottom wire exit.
ronwhite
Ironhead
Aug 24, 2018 01:21 PM
charris
Jan 23, 2014 11:44 AM
cptron
Sep 20, 2011 11:46 AM
jedsled
May 15, 2011 10:28 AM
Shotglass
Feb 10, 2010 12:40 PM
