bike wont start
Old Feb 9, 2010 | 06:00 AM
Shotglass's Avatar
Shotglass
Default bike wont start
I have an 08 Electraglide standard and I went to start it the other day after work and I heard a slight pop and then all it would do is turn over but not start, any ideas??
Old Feb 9, 2010 | 07:05 AM
troy.j's Avatar
troy.j
have you pulled your codes?
Old Feb 9, 2010 | 07:54 AM
Geezr Glidr's Avatar
Geezr Glidr
Do you fire it up once in awhile without going for a ride? I made this mistake last winter, on my Yamaha Stratoliner (bought a Harley last May) My carburated V Star had no problem. I guess fuel injected bikes can't be fired up. Letting them run for a few minutes doesn't make them burn as hot as it would if you went for a ride. I started the Stratoliner once in awhile last winter until, one day, it turned & turned & turned but wouldn't start up. Found out that I mucked up the plugs & had to have somebody come get it. Then I was told to put the trickle charger on it & no matter how tempting it is, don't fire it up! If that's what you've been doing, better get somebody to look at the plugs. You probably didn't hurt anything. I didn't --- only the plugs.
Old Feb 9, 2010 | 08:19 AM
stro1965's Avatar
stro1965
Start with the simple stuff first. See if the bike is throwing a code, see if it's getting spark, and see if it's getting fuel, then report back.
Old Feb 9, 2010 | 09:21 AM
mainshaft's Avatar
mainshaft
Blown fuse??
Old Feb 10, 2010 | 05:53 AM
Shotglass's Avatar
Shotglass
I replaced the maxi fuse, cleaned the plugs, I get spark in the front cylinder but not the rear.
Old Feb 10, 2010 | 12:17 PM
stro1965's Avatar
stro1965
Hmmm...coil? Bad plug or plug wire? Are you SURE it's getting fuel?
Old Feb 10, 2010 | 12:40 PM
jdreed520's Avatar
jdreed520
If you are getting spark on one then i would change the coil first.....but i would recheck the fuses........
Is there fuel pump running? can you hear it when you first turn on the key?
hotdotdog
Electrical/Lighting/Alarm
Oct 24, 2023 05:26 PM
HOGDAT
EVO
Dec 7, 2014 06:38 AM
cptron
Sep 20, 2011 11:46 AM
hollywood1959
Apr 23, 2009 07:39 AM
128auto
May 16, 2008 10:24 AM
