Screaming Eagle Spark Plug Heat Range?
Old Jan 19, 2022 | 08:06 AM
HDkazHD's Avatar
HDkazHD
Default Screaming Eagle Spark Plug Heat Range?
May I know what's the Heat Range for the 32192-10 Screaming Eagle spark plugs? I just pulled them out from my 2012 FLHR and they doesn't look pretty. Will need to get some NGK replacements.
Old Jan 20, 2022 | 08:12 AM
bustert's Avatar
bustert
what are the actual numbers on the plug itself?
they are made by champion to hd tight spec's. champion uses a rising number system for heat ranges. if you want to change brands, cross the standard hd plug number to what ever brand you want. remember, plugs are riddled with all sorts of unfounded info. the screaming eagle just uses a better plating and exotic electrode and ground material that helps them fire in high performance engines. they are not any better in a stock engine.
Old Jan 20, 2022 | 11:04 AM
hrdtail78's Avatar
hrdtail78
DCPR7E are stock replacements. DCPR8E are one step colder and 4179 are solid tops. Sorry I don't have the solid top PN for the 7's.
Breakout2018
2018+ Softail Models
18
Jan 3, 2022 12:26 PM
Geoff
Jun 30, 2018 11:40 PM
bluedeuce4
Jun 28, 2012 11:59 PM
Chief101
Apr 29, 2012 10:59 AM
DSG
14
Apr 6, 2012 05:46 PM
